Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-14-2007, 10:02 AM
Zom's Avatar
Zom Zom is offline
Unhappy Break lights don't work on 98 explorer
I have a 1998 Explorer. Last night I was told that I had no break lights. Upon checking them out this morning I found this to be true. The thing is the parking and tail lights still work. I tried replacing the bulbs and fuses. Any help would be appreciated. Thanks
Old 10-14-2007, 11:20 AM
denisb denisb is offline
Re: Break lights don't work on 98 explorer
My guess is pedal switch if you checked fuse and bulb. If that's not it, you can check for continuity from the pedal switch to the brake light contact.
When you said no brake light, did you try with the park lights on and off. The reason I ask is that I've seen some funky stuff happen if you have a bad ground. Somethimes you'll see dim brakes with brighter park lights etc. This is due to the current going thru both filaments instead of going back to ground.
Denis
Old 10-14-2007, 12:51 PM
Zom's Avatar
Zom Zom is offline
I found the pedal switch. I was able to get it inplugged but I can't figure out how to remove it. It seems like it may have a pin holding it on. But i didn't want to pull on it too much.
Also, I went to ford direct online to try to find the part. They list no such part. Is there another more technical name for it? Thanks again.
Old 10-14-2007, 01:49 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Brake light switch, stop light switch, Brake Off/On switch. You can find these switches at your local aftermarket auto parts stores.
Here is a place that has the switch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-14-2007, 05:00 PM
Zom's Avatar
Zom Zom is offline
Yes thats the part. I was able to remove it. I'll be picking a new one up tomorrow. Hopefully it will fix the problem. I'll post on it either way. Thanks!
Old 10-15-2007, 02:57 PM
Zom's Avatar
Zom Zom is offline
I got the switch today. I attempted to put it on but I can't figure out which way it goes on. When I took the old one off a small plastic bushing came off with it. the new one did not have the bushing but I still have the old one. When I put the rod through the hole is the rod supposed to go all the way through or can the pin be inserted in the middle? I can't get the rod to go far enough for the pin to go in on the outside. Aside from being after market, The parts are exactly the same.
Is it possible for one of you to snap a pic of what it's supposed to look like installed? I should have taken one before I got started. Thanks for your help.
Old 10-17-2007, 08:13 PM
Zom's Avatar
Zom Zom is offline
anyone?
Old 10-18-2007, 01:51 PM
way2old's Avatar
TOKEN HILLBILLY
Sorry for delay. Click here for a site that has repair information. There is a picture that if you click on it will show how to install.
Old 10-18-2007, 11:01 PM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
Make sure the bushing goes back on, I know first hand what happens when you dont use it. It was not pretty.
Old 10-19-2007, 04:33 AM
Zom's Avatar
Zom Zom is offline
Thanks guys. I'll update once I get it installed.
Old 10-21-2007, 11:33 AM
Zom's Avatar
Zom Zom is offline
Unhappy Re: Break lights don't work on 98 explorer
I guess I'm an idiot. I can't get the damn thing back on there.
Old 10-21-2007, 02:06 PM
way2old's Avatar
TOKEN HILLBILLY
Read this page again
