Old 10-14-2007, 08:53 AM
darkserpant darkserpant is offline
both daytime running lamps don't work
I have a 2000 cavalier and all of a sudden both daytime running lamps are out. The head lights work but the running light do not. Is it likely that both head lights are at the same time? Thanks
Old 10-14-2007, 10:15 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: both daytime running lamps don't work
do either of your high beams work?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-14-2007, 11:51 AM
I just went out in checked. Right when I start the car my running lamps work for a spit second then they act like they are shorting out. Then I turn on my headlights and they work, now when I go to turn on my high beams only one of then work and nothing from the other side.
Old 10-14-2007, 06:09 PM
sounds like it could be a bad DRL relay
Old 10-14-2007, 11:29 PM
Derk_eliso's Avatar
Derk_eliso Derk_eliso is offline
Send a message via AIM to Derk_eliso Send a message via MSN to Derk_eliso Send a message via Yahoo to Derk_eliso
big black fuse in your fuse box inside the car
Old 10-17-2007, 10:45 PM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
well at least for my car ('98) if one high beam is out both DRL's don't work...mine turned out to be a connection going bad since there were times when the lights worked, but most of the time they didn't...it was kind of annoying going down the road winking at the other cars...(low beams suffered the same problem)
damn connectors cost me about 50 bux for both of them...i know i know...i should'ah gone to a junkyard or something but i wanted more of a guarantee that they would work.
if your one bulb isn't burned out, wiggle the wire when you have your high beam on and see if you get power to it. if you do, you need to replace the connector more than likely.
