Old 10-13-2007, 10:58 PM
gsh4386 gsh4386 is offline
Best way change the Throttle position sensor?
Anyone have suggestions on the easiest way to get the torx screws out? Should I use a socket torx bit and what should I move out of the way?
Old 10-14-2007, 06:28 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Best way change the Throttle position sensor?
What year Blazer & motor are you referring to?
Old 10-14-2007, 09:46 AM
2000 LT 4x4 4.3L
Old 10-15-2007, 10:37 PM
AF - Advisor
My '97 was totalled, I'll check my daughter's 2000 S10 when she gets home.
Old 10-16-2007, 12:05 AM
AF - Advisor
Looks like the intake air duct and thermostat housing gooseneck need to be removed to access the TPS.
You'll need to drain some coolant.
