Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 10-13-2007, 07:27 PM
charlo8877 charlo8877 is offline
1997 Town car Trunk wont open
I have a '97 TC. When I press the trunk lease button on the driver's side door the trunk will not open. I can only do so now by placing the key in it. When I press the trunk release button I hear a click but the trunk wont open.
Thank You in advance for your help.
Old 10-13-2007, 07:36 PM
emt1134 emt1134 is offline
Re: 1997 Town car Trunk wont open
You'll have to check the circuit.. simplest thing to do right now would be do check the fuse powering the trunk actuator
Old 10-13-2007, 09:00 PM
I already checked the fuse and that's fine. It's a 15 and it's intact. What else could it be ????????????????
Thanks
Old 10-13-2007, 09:09 PM
you really need the wiring diagram to test the circuit... It could be anything from an open in a wire, to a bad trunk motor.. check for voltage and ground at the actuator connector
Old 10-15-2007, 11:28 AM
phrawg phrawg is offline
Hold on a minute here, He said he heard a click when the button was
pushed. If that click is in the trunk then the fuse and wiring have to be ok.
Go to the trunk and inspect the latch and motor unit for a mechanical
problem. Kinda like "this lamp does not work but another one plugged
in the same outlet does". In fact most of the lights on the house do too.
Guess I will go check the main house breaker. !! ????? The click
indicates there is something electrical reaching the trunk. Have a helper
push the button while you examine what is happening in the trunk.
My stable:
1993 TC Sig
all black 82k
1998 Conti
pearl finish
off white
91k
