Old 10-13-2007, 06:46 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Lightbulb found older si civic
looking through the junk yard today and found an older must be 87 or older si 3 door untouched its a1.5 mpfi my question is can i use this car for a mpfi swap on my 91 dx
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 10-13-2007, 07:19 PM
trev0006 trev0006 is offline
Re: found older si civic
I have heard you can with a little mounting adapters, not 100% though..
Old 10-13-2007, 09:04 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
why would you?! that manifold is horrible.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-13-2007, 09:28 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
gah... make sure if it's an 87 or 88... if it doesn't look like the front end of your car, the manifold is crap, not worth your time, and nothing works the same as the 4th-4th gen swap.
There are plenty of parts for sale really cheap on this forum, as well as many other places nationwide that will hook you up w/ everything you need to do the swap PROPERLY.
Old 10-13-2007, 11:31 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
whats easier is just see if the back of the car is flat, then its definitely a 87, and I wouldn't touch it. Just get you a 4th gen manifold
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-14-2007, 01:23 PM
yeah, that's true, didnt' think about it... if it's a CRX, and it doesn't have the glass above the tails, it's crap... if it's a hatch, well, check the rear suspension, that will solve everything... if it has an axle tube between the tires, don't use it.
I happen to own a 1985 CRX HF that's getting a 'teg motor swapped in, w/ a turbo. Plan on bracketing it, maybe next season.
Old 10-14-2007, 11:17 PM
Tony's Avatar
TLD Member #1
lol...thats my race car for next year, 86 CRX with a Z6 in it(not in yet, but soon, not like my other plans). Can you pull your car around with one hand and walking?
Tony
Old 10-15-2007, 12:37 AM
Nick Gautreau's Avatar
Nick Gautreau Nick Gautreau is offline
Send a message via MSN to Nick Gautreau Send a message via Yahoo to Nick Gautreau
I can .................................................. .................................. on a slope! <
Originally Posted by Dr0pZ0n3
I just think it's funny to pull up to a redlight in a beaten 4dr against some oldie in his "muscle" car... rev the lil tiny snowblower motor against his loud ass V8, then leave him sitting there when the light turns green...
1990 Honda Civic DX - Getting custom!! Needs battery
I need parts for my car. Please contact me via PM if you have anything to get rid of
Old 10-15-2007, 02:25 AM
actually, the car is parked behind a friend's garage.. it' sout of gas (on purpose) so they couldn't get it started, not to mention they don't have the keys to it... so guess how they moved it?
Two 50 year old guys picked the car up... and it has the stock engine in it still... lmao. My dad and his friend MOVED MY CAR MANUALLY... I was quite amazed the geezers still had it in them :P
Old 10-15-2007, 11:31 AM
Tony's Avatar
TLD Member #1
Lol, thats how me and a friend got the motor out of mine, didn't have an engine hoist at the time, so I dropped the engine on the ground, me and him picked up the car and moved it. Right now its in my back yard and to move it, I just grab it with one hand and start walking, but mine don't have doors, bumpers, or the front bulkhead on it
Damn it, I'm going and thread jacking again
Tony
Old 10-15-2007, 11:40 PM
umm... I removed the engine by hand from all three of my honda's... just me, never had a friend.. usually wrap a board & chain around it, unbolt everything, then just lift it up and out... and I"m not a big guy, by any means..
Old 10-16-2007, 03:55 AM
FrodoGT's Avatar
They weigh about 150-200 depending on the engine, I believe thats longblock only.
Current project:
Rio Red 91 hatch.
Old 10-16-2007, 10:55 AM
We weighed in a D15B2 @ close to 300, that was with all accesories, alternator, engine harness, and A/C pump.
But, if you position yourself right, you can place your own arms as leverage against the car, and lift the engine up high enough to get it on the fender, then pull it out from there... (duh, this goes w/o saying, use a tack mat on the fender, so you don't beat it up.)
Old 10-16-2007, 03:49 PM
Tony's Avatar
TLD Member #1
You mis understood me....we lifted the CAR over the engine, not the engine out of the car Otherwise most of the time its only me working on my cars, might have a friend come over just to motivate my ass to go outside and work on it.
Tony
Old 10-16-2007, 11:48 PM
oh, no, I knew what you were saying, I was just quoting what we weighed in the engine at. tranny, add about another 100 lbs or so.
