Old 10-13-2007, 05:26 PM
GeeBee63's Avatar
GeeBee63 GeeBee63 is offline
Send a message via MSN to GeeBee63 Send a message via Skype™ to GeeBee63
WIP, Tamiya Mini Cooper
Had this on the go for around a year, after being busy with other stuff, i am just making another go on it, i'm building another one as well in a different colour (White with a black roof) and also converting a Tamiya cooper kit to a basic mini
Old 10-13-2007, 09:34 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: WIP, Tamiya Mini Cooper
Welcome to AF!
Looks like you're off to a good start. The Tamiya Mini is a great (if tiny) little kit.
If you want to add some additional engine detail, I might suggest wiring the ignition system. The spark plugs, distributor, and ignition coil are all easily visible on the front of the engine. You just need some fine guage wire and a suitably sized drill bit.
PHOTOBUCKET SUCKS
Old 10-14-2007, 06:20 AM
GeeBee63's Avatar
Yes, i am going to wire up the ignition, i should have really drilled the holes before i painted it, but there's always something you forget to do .... the holes in the wheels were drilled out, instead of painting the indents black, like shown in the instructions, the paint is factory tartan red and black.
Here's a few more photo's since the last lot, coming on quite good ....
Old 11-04-2007, 03:33 PM
GeeBee63's Avatar
Photo's taken since last time ......
Bodywork on the white & black one has just been started .....
Geoff
Old 11-13-2007, 09:08 AM
GeeBee63's Avatar
Front end is now finished, just the rear to do, plus door handles, badges and a few decals to do, then it's finished.
Old 11-14-2007, 08:18 AM
kallum kallum is offline
that looks great i attempted one but myne snapped in post so i wasnt happy any way keep going looking good so far.
Old 11-15-2007, 03:37 PM
GeeBee63's Avatar
Work on the Old English White cooper is starting to come along ...
Engine built up and fixed into front subframe
Engine put into chassis, Dynamo drive belts, cooling fan and radiator fixed in
Rear subframe, exhaust and gearbox remote casing installed
Dash panel painted, just gauge decals to install
Carpets painted Tamiya flat red
Bottom of Gearbox, drive shalfs and steering installed
Rear boxes painted and trimmed in BMF
Bodyshell & roof painted and polished
