Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-13-2007, 01:17 PM
BigMikeyB's Avatar
BigMikeyB BigMikeyB is offline
Send a message via AIM to BigMikeyB
EEC code?
I'm trying to get a custom tune for my '93 crown vic LX, but I have no idea where/how to find the EEC code off the EEC.
Please help me
Old 10-14-2007, 07:24 PM
KCMike's Avatar
KCMike KCMike is offline
Re: EEC code?
Are you just wanting to see what codes are in your EEC system?
KCMike
ASE Automobile Master Technician
L1 Advanced Engine Performance Certified
http://www.automotiveresource.org
Old 10-14-2007, 07:29 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: EEC code?
Remove the PCM and look where the wiring plugs in. There is a part number on it It will be like XXXX-12A650-XXXX. Then there are more numbers there that you want to use.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-15-2007, 11:42 AM
BigMikeyB's Avatar
Re: EEC code?
Thanks!
One more thing though...
could you possibly enlighten me as to the location of the PCM?
Just got this thing a week or so ago, still not intimately acquainted as of yet.
Thanks again!
Old 10-15-2007, 11:59 AM
KCMike's Avatar
Re: EEC code?
Originally Posted by BigMikeyB
Thanks!
Thanks again!
Look under your dash on the far left side. I believe it is mounted with the connector end up against the firewall.
KCMike
Old 10-15-2007, 07:10 PM
way2old's Avatar
TOKEN HILLBILLY
Re: EEC code?
Up under the dash on left side . There is a 10mm bolt that holds the wiring to the PCM that is under the hood between the brake booster and fender. Then there is probably a plastic clip the holds the PCM to the bracket. Remove the clip and work PCM out of bracket. It is a bsilver colored box that is about 4x5 inches.
