Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-13-2007, 12:19 PM
drichar056 drichar056 is offline
Freeze Plugs
My daughter decided to drive our 96 rodeo 3.2L V6 through the garage wall into the kitchen. This resulted in the replacement of several parts, one of which is a new radiator. Since replacing the radiator we are still having major antifreeze leaks. The hoses and the connections are dry. I thought it was the water pump but the coolant leak appears to be located on the bottom of the engine near the front of the oil plan. There is no coolant dripping from the bottom of the water pump area.
This makes me think it is not a water pump. I have been told a possibility is a freeze plug but to be honest I cant find them nor can I find anything on the internet that tells me how to find them.
My questions are...
Could the freeze plugs be the culprit?
Where are they on the engine and how difficult are they to replace?
Thanks
Old 10-13-2007, 02:47 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Re: Freeze Plugs
Refer to the thread below. It might help you out.
http://www.automotiveforums.com/vbul...d.php?t=755751
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 10-13-2007, 06:46 PM
boritz's Avatar
boritz boritz is offline
Re: Freeze Plugs
Originally Posted by drichar056
...the coolant leak appears to be located on the bottom of the engine near the front of the oil plan. There is no coolant dripping from the bottom of the water pump area...
Is it possible that you are confusing the radiator fan pulley with the water pump?
The water pump is mounted internally, behind the timing belt covers, and a leak from it would exit at the bottom of the lower cover "near the front of the oil pan" as you describe.
Just a thought.
Old 10-13-2007, 08:59 PM
Cat Fuzz Cat Fuzz is offline
Re: Freeze Plugs
What he said ^^^^^^
The thing the fan is mounted to is simply a bearing. The water pump is driven by the timing belt and can't be seen unless you take some stuff apart.
