Go Back   Automotive Forums Car Chat > Automotive Art > Remote Control Cars
Remote Control Cars Questions, comments or discussions on the wonderful little vehicles.
Old 10-13-2007, 09:04 AM
naruto's Avatar
naruto naruto is offline
Banned
High Compression
Hey all,
I was wondering if raising the compression ratio on nitro engines have any negative effects?
I ask because i have already done so, but i am yet to take it for a hard spin. I've only removed the standard cooling head shim and sanded down the cylinder sleeve(if that's what it's called..lol).
I thought I'd give higher compression ago only because i needed to rebuild the engine due too falling into a ditch full of water.
Thanks in advance
Bryan
Old 10-14-2007, 04:09 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: High Compression
raising the compression is only used to run a higher percentage of nitro, it doesnt increase power on the same nitro, it may even run worse now that you did that.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-15-2007, 01:07 AM
naruto's Avatar
Banned
Hmm. well i've just run out of petrol so i'll get some with higher nitro percentage, the engine size is .15 and i'm currently using %15 what do you think i should or can use?
Thanks mate your a big help
Old 10-15-2007, 05:02 AM
pre98zetec's Avatar
if it was broke in and ran on 15% its a bad idea to change percentages this late in the game.
i would just spring for a new motor if its wore out, run that one on 20% though
-Josh-
Old 10-16-2007, 03:15 AM
naruto's Avatar
Banned
cool, good thing you said 20% i would of definitely gone higher. I've got a stable job now so i will get a massive engine like i planned before i just hope gears for a TGS-R aren't expensive.
Old 12-17-2007, 11:42 AM
lotus_man's Avatar
lotus_man lotus_man is offline
Raising the compression ratio (i.e. removing head shims) will tend to push combustion earlier in the cycle for a given nitro %age, which taken to extremes will cause detonation, more heat and a lot of stress on your motor. If you have removed shims from the head you want to DROP the nitro %age you run not increase it as that will increase the likelly hood of detonation.
There are plenty of good sites out there with information on how this all works! Best check them out before doing potentially expensive damage to your motor...
My current work-
