hazard weirdies
i turned on my hazards the other day.
parking in the road to run inside and get a forgotten wallet kind of thing. so anyway. all the turn signals and everything are still working properly, but when i turned on the flashers, all four lights just stayed on steady. they got brighter, as if to flash, then no flashing. weird. btw it's an 85 chevy c10, with some work done, but nothing that would affect lighting. also, i should point out that they were working properly when i last used them several weeks ago. nothing has been done in those weeks, just the occasional workout drive.
all your are belong to us.
Re: hazard weirdies
ive got a 97 and when i apply the brakes the lights stay solid, then when i release the breaks the return to flashing. I guess its so when you stop people behind you can tell better. when the flashers off, are your brake lights functioning? if not, you may want to check the switch
Re: hazard weirdies
Kinda sounds like the relay might of went out.
Re: hazard weirdies
There is a separate flasher (clicker) for the 4way emergency lights and sounds like a likely suspect.
BobB |
Re: hazard weirdies
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
