Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-12-2007, 11:33 PM
Paulf985352 Paulf985352 is offline
96 Olds 88, not getting fuel
I have a 96 Olds 88, It started 2 days ago(for about 5 min). I turned on the heat, rear defrost, and when I tried to use the power window it stalled(not starting back up). I tried ether and it starts fine, leading me to believe it is not getting fuel. I cannot hear the fuel pump run when I turn the key. Then I noticed the power windows are not working. Could this be some sort of electrical problem like a fuse or relay not getting power to the fuel pump? If it is the fuel pump, why did the power windows quit?
Old 10-13-2007, 08:48 AM
maxwedge maxwedge is offline
A990 racer
Re: 96 Olds 88, not getting fuel
Welcome to AF, this can be the common issue of a bad ground connection for these circuits under the l/s front carpet just inside the sill, there is a common buss ground junction that can corrode, open the harness covering to check.
Old 10-13-2007, 09:27 AM
Mickey#1 Mickey#1 is offline
Here's a link to an article with some pics showing the location of the ground bus. The fuel pump grounds on the driver's side. The ground bus is the connector that has all the black wires going to it. 99.9% chance this is the problem.
http://www.bonnevilleclub.com/forum/...=article&k=102
Old 10-18-2007, 04:42 AM
happyrhodes happyrhodes is offline
My 1988 Olds 88 is not getting fuel either. I can hear the fuel pump shutting down after I turn the key off. I can't hear it start up when I turn the key on though. Would you think the pump is working?
Old 10-18-2007, 02:57 PM
A990 racer
Different car and issue, please start a new thread.
