Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 10-12-2007, 08:55 PM
blksrt4_2005 blksrt4_2005 is offline
i need help with code
my car is throwing out the code p2096....i looked it up and it says its running half lean...but im only running 18psi dropping to 14 or 15psi....it started trowing out that code after i added the needswings downpipe with a cut out....its not throwing out the overboost code or the no cat code (wierd)....
1)my car has a new ACT clutch..
2)ngk iridiums plugs gapped at .44...
3)new wires.
4)mopar exhaust....
5)3inch downpipe with cut out...
6)mopar intake
7)motor mounts
8)mopar bov.
can it be my fuel injectors? maybe their clogged....any help will be appreciated....my car is running good i dont feel any difference....
Old 10-12-2007, 09:13 PM
emt1134 emt1134 is offline
Re: i need help with code
Unfortunately, this is one of the drawbacks of doing modifications on modern vehicles. The computer is programmed to run off factory equipment, so when you start decreasing backpressure by adding bigger exhasut, or getting after market cat. converters, or anything else for that matter, the computer may see higher or lower values than expected. so you might not even have anything wrong with the car, just that the computer doesnt like what you have done
Old 10-12-2007, 09:55 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Actually you ARE throwing the no cat code. Since you are on the stock s0 computer without a cat(using the cutout downpipe) you are throwing the catless code. Just FYI, when not using a cat and not using s1+ computers you can either get a p0420 or p2096.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 10-13-2007, 03:40 AM
oh that explains it all...thanks....cuz my car is always runnig too rich i think....cuz when its ideling you can hear it popping like every 15 seconds......
Old 10-13-2007, 02:09 PM
Turbodog97's Avatar
Just a Neon
That's normal. Every srt does it.(the popping every few seconds at idle)
05 Srt4
97 Mx-5
Old 10-13-2007, 08:10 PM
thanks for your help...
Old 10-17-2007, 12:35 AM
airwave_assassin airwave_assassin is offline
Send a message via AIM to airwave_assassin
how do you get this code to turn off, you know for inspection reasons
Old 10-17-2007, 09:24 AM
Turbodog97's Avatar
Just a Neon
Well you could either:
1) Put a cat on
2) Get s1+ pcm
3) Pull up to inspection place, pop hood, pull battery cable off to reset computer and hope it doesn't turn back on in the time you're there.
4) Try the "non-fouler" mod...basically you put this extra piece of metal inbetween the o2 sensor and bung in the downpipe and it's supposed to fix it...who knows though.
05 Srt4
97 Mx-5
Old 10-17-2007, 11:29 AM
No, you cannot just clear the code and run the inspection right after. I believe it is mandatory now that all inspection stations run inspections through the OBDII connector if the vehicle is 1996+. The dealer that I work for does. When you clear the computer, you must reset the I/M flags for each diagnostic test. Usually this requires a few days of driving. If you are lucky, however, the catalyst test will run, but not fail.
Old 10-17-2007, 10:20 PM
Turbodog97's Avatar
Just a Neon
Not all counties make you do an emissions testing and diagnostic testing and such. As long as you don't have a cel you're fine.
05 Srt4
97 Mx-5
