Do I REALLY need the front hub nut tool?
I plan on repacking my bearings while working on the brakes. I have everything I need, except the hub nut tool. Do I really need it or can I use a screwdriver to tab the nut to remove it?
Isn't there a axle tool that fits without modification?
1994 Acura Integra LS---212K+ 1998 Isuzu Rodeo S 3.2L 2WD---176K+ |
Re: Do I REALLY need the front hub nut tool?
No, you do not need a special tool. You are only removing the bearing pre-load spindle nut, and it should not be very tight. You can jimmy it around with a drift or screw driver. There are holes in it to push it from.
There is a special tool designed just for this nut (seems like I've seen it priced at $13 or so), but you do not need it. |
You can do it with hammer and punch/screwdriver. I just find it easier to get the bearing preload setting right using the modified ford hub nut tool. Either way works so up to you.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
If you don't have an in/lb torque wrench (like me) you can make a pin spanner (face spanner) out of some flat bar, bolts and nuts, with a short arm like a 'Y' shape. Then use a fishing spring balance to get the right pre-load. Make the handle of the spanner reasonably long because you first have to load up the bearing to get everything seated, and then back it off and get the correct pre-load.
On my 99 Rodeo I made the leverage distance 4 inches, so the required force is about 10 lb. Cheers, Andrew. |
i used a flat blade screw driver,worked great! the real issue for me was getting the three phillips screwws out of the retainer ring! mike
2006 liberty 3.7 6speed manual 1999 cherokee classic 4.0L 1991 wrangler yj 2.5L 2001 caravan 3.3 auto 1995&1992&1994 camry 2.2L SOLD 1991 silverado 1500 SOLD 2000 rodeo SOLD
After having problems with the first one, I used a hand impact driver on the rest, and that popped 'em right out on the first smack with no difficulty & no damage to the heads. |
once i got the phillips screws out (all 6) i then replaced them with hex head (male) small bolts (same thread and length). now when i pack or tighten the bearings i put a socket on them and they come right out! mike
p.s. i wish i had thought of the impact, at the time!
Thanks, Tom |
You don't need one. If you wanted to buy one, Performance Tool sells a socket just for an Isuzu. I believe it's around $13. You'd have to order it b/c most parts stores don't stock it.
I used an appropriate sized allen wrench to spin the nut off. Find one that fits the hole and you're set to go. The nut is just snug not tight so it's easy getting it off. Also, I bought a bearing repacking tool. I actually used the tool on one side and hand packed the other. Just wanted to try both. I would suggest that you check your rotors and pads while you have everything off. I replaced the rotors, pads, and repacked the bearings. I just like doing things all at once while I have everything removed.
Thanks for the info! I typed axle greaser but was thinking bearing packer the whole time! Last time I packed them by hand too, didn't seem to hard just took forever. My hole mess started because I wanted to replace the rotors on my Trooper and got stuck at the bearing retainer/axle nut. I think I got it figured out now, this forum is uber helpful, you just gotta be patient sometimes!
Thanks again, Tom |
Packing bearings is easy with a grease gun and needle injector. You can squeeze the grease between each individual roller in no time.
