Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 10-12-2007, 12:08 PM
gavansdad gavansdad is offline
Exclamation 96 Stratus-No fire
I've been working on this Stratus for 3 days. Replaced the Ignition Coil, Starter, Computer, Battery, Camshaft Sensor, Crankshaft Position Sensor. Now I'm not getting any fire. Does anyone have a suggestion?
Old 10-13-2007, 08:55 AM
jdl jdl is offline
Re: 96 Stratus-No fire
Did you check for codes? Can you check the primary circuits at the coil pack? The primary circuits are the smaller wires, not the plug wires. The dark green/orange wire at the coil pack should be hot with the engine cranking, is it? If it isn't, that leads back to the asd relay, I'm not saying replace the relay, you have to do some testing. The other primary wires should be grounds, with the engine cranking, there should be a dc pulse on those circuits.
