Old 10-12-2007, 11:27 AM
blu3kgt blu3kgt is offline
cel code p0400
my cel just came on a couple days ago... i haven't tried to remove the egr system or mess with it in general.... i just want to fix it, i know it's egr related but i want to know what is causing this problem.... is it the egr valve itself that needs to be replaced???
Old 10-14-2007, 11:36 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: cel code p0400
http://www.3si.org/forum/showthread....&highlight=egr
basically any posts on 3si by Struggly mentioning 'egr', 'cel', 'obdII' would be pertinent to your situation.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-14-2007, 06:31 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: cel code p0400
You turbo or no? Make a sig with your car info. in it, makes it easier for us to help you out.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-14-2007, 08:30 PM
Re: cel code p0400
it's a 97 sohc
Old 10-14-2007, 11:19 PM
Re: cel code p0400
It's possible it's the EGR itself getting stuck open or closed. Could be the vacuum hose to it fell off or is leaking. Could be the EGR ports in the manifold are clogged or the EGR pintle is clogged up.
If you don't have a scanner to command it to open and close, I would start by removing it and looking for clogs. If they're there, see if you can clean it up.
