Old 10-11-2007, 07:51 PM
Rick140156 Rick140156 is offline
August 1993 Geo Metro, Starting problems
I have a 1993 non fuel injected Geo Metro with only 76000 miles. We've had sporadic problems with starting the car. Once it's started it runs fine. This has been happening with engine hot or cold. I've changed the fuel filter by the gas tank, added gas treatment. But can't figure why this is happening. I have no problem cranking the car over, Could it be no spark or bad points? I could use some help.. Thanks.
Old 10-12-2007, 07:10 PM
ammcf1 ammcf1 is offline
Re: August 1993 Geo Metro, Starting problems
I had a similar problem on my '94 - it ws the positive battery cable, where it connects to the battery. The wiring had corroded enough that it was not making consistent contact with the clamp that attaches to the post. I re-spliced it and put on a new clamp and it works like a charm!
Old 10-13-2007, 12:44 AM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
Can you give some more details about what happens when you try to start? What do you here? What kinds of things have you checked when it doesn't start? Once you have it running, if you make a short stop, does it start easily, or is it the same thing all over again?
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
