Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 10-11-2007, 06:17 PM
kyleholt11 kyleholt11 is offline
Angry Tranny Vibration???
I have a turbo 350c tranny the starts to vibrate when i get it up to about 1500 to 2000 rpm in amy gear...How can i fix this problem???
Old 10-11-2007, 06:44 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Tranny Vibration???
You may be missing a torque converter bolt, you may have a broken or cracked flexplate, or you may have a weight missing on the torque converter.
That's where I'd center my investigation.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-11-2007, 07:14 PM
maxwedge maxwedge is offline
A990 racer
How about in neutral?
Old 10-11-2007, 07:58 PM
yes it also vibrates in neutral.
Old 10-12-2007, 12:54 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Deffo something torque convertor related. Also check both motor mounts and the transmission mount while you're down and dirty.
Bob
Old 10-13-2007, 04:26 PM
would a torque converter off of a TH350 work on a TH350c? I know it wont have the lockup capabilities but will it fix the vibration problem?
Old 10-13-2007, 07:14 PM
A990 racer
Not the way to do this, plus I think the input shafts are different, some will jump here and confirm this.
Old 11-04-2007, 07:52 PM
wannablast wannablast is offline
Is this vibration while sitting still or while rolling? I had a problem once with universal joints. They gave me a vibration with different driveline loads and at diffirent speeds until they failed.
Old 11-04-2007, 10:34 PM
silicon212's Avatar
Confoundingly Lucid
I ran a lockup converter on a non-lockup TH350 for a year before the converter failed. This was in 1998 when I flipped burgers for a living and couldn't afford a proper replacement unit. It can be done, but don't expect longevity out of it.
Old 11-05-2007, 12:27 PM
bobss396's Avatar
Bad u-joints usually can be heard before they cause trouble. At low speeds they give off a chirping sound. A visual examination will show signs of rust coming out of the caps, meaning that the grease seal has failed and water is getting in.
Bob
Old 11-05-2007, 02:46 PM
A990 racer
Guys according to the OP this thing vibrates in neutral, not the U' joints in that case.
Old 11-05-2007, 07:18 PM
yeah it vibrates in nutural when i rev the engine 2000-3500 RPM...
Old 11-06-2007, 03:45 PM
silicon212's Avatar
Confoundingly Lucid
My money is still on the torque converter, flex plate, or internal engine balancing. Probably not the latter, if this came on suddenly.
Old 11-06-2007, 06:40 PM
A990 racer
Correct, or a bad fan blade on the water pump.
Old 11-07-2007, 07:11 AM
Thanks. My friend gave me a 700R4 yesterday and I was wandering if I am going to switch crossmembers or If I can keep the same one on my truck?
