Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-11-2007, 03:37 PM
ncerny ncerny is offline
95 possessed camaro problem starting
I have been having this problem for quite some time and am very frustrated. This only happens the first time the car is started for that particular day. Once it throws its little fit, then the car will start and run fine for the remainder of that day (drove it over two hours and ran fine the whole time). After the car is started it will run for a few seconds and then die out. It will miss fire and act as though its not getting fuel or unable to spark. After starting it for 5 or 10 minutes and letting it idle the car will run perfectly fine. I have replaced all the plugs, wires, the coil and ignition module, the distributor, and just had the computer replaced. Sometimes it will turn on, seem like its running fine and then die out a block away or so leaving me stranded until it decides to run again. I would greatly appreciate any help somebody could give, I have wasted alot of money on this and would really just like my car to be reliable.
Old 10-12-2007, 01:28 AM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Re: 95 possessed camaro problem starting
maybe its your fuel pump, somebody else had the same problem, myself included. On mine, it was the same thing, ran good for a couple of days, and then started dying on me until it just gave out, and this was maybe......a month or so. Chenk into it before you spend more than what you have already.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
