Old 10-10-2007, 11:07 PM
hipergsx1990turbo hipergsx1990turbo is offline
turbo
what size turbo should i go with my 06 silverado im going 3 inch piping and rear mounted and intercooled im doing everything my own everything is stock
Old 10-10-2007, 11:12 PM
bigbadram51 bigbadram51 is offline
Re: turbo
Im not sure what size turbo you should really use. A lot would depend on how much boost you want to run. Why intercool and rear mount it. One of the big advantages of rear mounting is your not sucking up hot air from the engine compartment. If your keeping everything stock, I wouldnt run more than 5 to 7 psi, so a smaller turbo would suffice.... Better yet just by the STS turbo kit designed for the silvy
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 10-11-2007, 12:15 AM
Re: turbo
well im planning to get bigger injectors and a fuel pump and get a good tuned for now and i would just like to get an intercooler cause it would look cool behind the grill right.
Old 10-11-2007, 10:54 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: turbo
Just because it looks cool doesn't mean it is worth the money spent. An intercooler just means more parts to break down. Like Bigbadram said, if it is rear mounted the Turbo does not need to be intercooled.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 10-11-2007, 11:34 AM
knogoodidleft knogoodidleft is offline
Re: turbo
and for the money saved on the intercooler you can purchase a moderate nitrous kit
Old 10-11-2007, 06:34 PM
vortecman's Avatar
vortecman vortecman is offline
Re: turbo
he wanted to install an intercooler for looks... doesn't sound like money is a concern...
