Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-10-2007, 10:38 PM
hipergsx1990turbo hipergsx1990turbo is offline
no start, no spark help!!
i had just finished an engine rebuilt and ready to start but nothing fuels ok but theres no spark it only sparks when i turn on the ignition key and the clutch pedal is engaged but when i disengaged the clutch engine cranks but no spark
Old 10-11-2007, 12:09 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: no start, no spark help!!
Originally Posted by hipergsx1990turbo
i had just finished an engine rebuilt and ready to start but nothing fuels ok but theres no spark it only sparks when i turn on the ignition key and the clutch pedal isnt engaged but when i engaged the clutch engine cranks but no spark
The car should only start when the clutch is disengaged. That is, unless you disabled the clutch safety switch. Remember engaged is the clutch out, disengaged is the clutch pushed in.
So on my car, if I crank (turn the key without the clutch pushed in) I get nothing. If I push in the clutch and turn the key the engine cranks.
It sounds like you're safety switch is doing its job. You just have a problem with spark or fuel. What tests did you do determine the lack of one or the other?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-11-2007, 12:27 AM
o yeah im sorry thanks about the engaging part but yeah its engaged and it sparks once whith out cranking but when i disengaged it cranks but no spark fuel is good changed the coil packs and still the same know what
Old 10-11-2007, 12:33 AM
Hmm plugs and wires are the cheapest things I would start off replacing. Cam angle sensor and crank sensor will also cause the car to not turn over. You said you just finished rebuilding the engine. I'm assuming you replaced the timing belt. Hopefully it didnt jump a tooth.
94 Talon 1.8L-SOLD
Old 10-11-2007, 01:00 AM
yes new timing belt timing is ok and new spark plugs and new wires what else can i checked
Old 10-12-2007, 06:30 PM
soto 95 gsx soto 95 gsx is offline
crank posision sensor have you check it
Old 10-15-2007, 11:26 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Have you tried grounding out the plug wires while you turn it over to see if you indeed do have spark?
1991 GSX 2.3 Stroker
