Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 10-10-2007, 08:36 PM
userunknown userunknown is offline
timing gear cover
wondering if you need to have timing gear cover or if it is optional also how to replace ignition switch on 87 jetta do you need to take off the whole sterring wheel?
Old 10-25-2007, 03:32 PM
Doug Tatham Doug Tatham is offline
Re: timing gear cover
The timing belt can be damaged by oil or other engine fluids. It can be too big a problem if it breaks not to protect it. You will want to remove the steering wheel when you replace the ignition switch. It's too hard to get to otherwise.
Old 11-05-2007, 02:59 AM
thanks i finally got the switch in but after much hard work
