Old 10-10-2007, 06:50 PM
cky369 cky369 is offline
1996 grand am security light
some times when i go out to my car it wont start it wont even try to start it just does nothing so i disconect the neg battery terminal and hook it back up and it starts just fine. or some times ill hit a bumb and my secerity light will turn on and my car will shut off leaving me stranded in the middle of the road when the light come on i just take my key out and start my car again i was wondering if theres any way to stop this from happening ive seen to cut the yellow wire but i dont want to go cutting wires if thats not my problem
Old 10-11-2007, 08:00 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 1996 grand am security light
Welcome to AF.
I wouldnt cut anything just yet.
Most likly a bad ignition switch or lock cylinder.
Next time try this.. relearn procedure!
1. Attempt to start the car by turning the key to the Start/Run Position.
2. Observe that the vehicle fails to start and that the security light is illuminated.
3. Release key to the 'ON/Accessory' Position. (DO NOT turn key to the 'off' position.)
4. Allow the vehicle to sit with the key in the 'ON/Accessory' Position for no less than 11 minutes.
5. Turn key to off position and allow the vehicle to remain in the 'OFF' position for no less than 30 seconds.
6. Repeat #1 - #5 for 3 cycles.
7. On 4th attempt, car should start.
NOTE : Since this is a fairly long procedure, I would limit all electrical sources, such as disconnecting headlights, to prevent discharge of battery.
NOTE 2 : It is SAFE to wait LONGER than the allotted time, but it is not safe to wait less time. I.e. 12 minutes instead of 11 minutes should be safe; however, waiting 10 minutes instead of 11 minutes is not safe.
Properly executed, this procedure should take approximately 35 minutes to complete.
1999 Grand Am SS 3.4 OHV
Old 10-11-2007, 04:19 PM
well does any one know the details to cutting the wire and where its located
Old 10-13-2007, 01:35 PM
The wire is located in the dash coming off the ignition switch.
I dont know the exact procedure for this , nor do I recommend doing this hack as other problems can occur.
Try searching this forum or the Grand Am forums for "passlock" or "passlock by pass".
I know its been discussed several times and many people have posted links to sites that can help with disabling the passlock system.
Good Hunting
oh yeah here is a link I posted a couple for the different models....
Passlock Disable- use at your own risk !
