Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-10-2007, 06:44 PM
Dspade Dspade is offline
Unhappy Crankshaft Position Sensors
Can someone PLEASE tell me where the upper and lower crankshaft position sensors are located on a 2001 Aurora 4.0? I have to replace mine very soon and need to know where they are located... Thanks for your help
Old 10-15-2007, 09:39 PM
ottoracefan's Avatar
ottoracefan ottoracefan is offline
Re: Crankshaft Position Sensors
The two crankshaft position sensors are located next to each other at the lower front center of the engine block. Put the car on ramps, remove the black plastic splash pan and you will see them. They each have a wiring connector that is a little tricky to remove if you have large hands and arms. A 10mm socket is needed to remove the single bolt holding each, a swivel and extensions come in handy.
Replace both sensors, if one is bad the other will be going soon. If you're going to make it a DIY job, buy them from one of the online GM parts sources. Some people (and the dealer) will tell you that a relearn procedure is required after changing the sensors - - it is NOT necessary, simply change them out and the computers will relearn during the initial start/shutdown cycles.
Old 11-01-2007, 10:55 PM
55624096 55624096 is offline
All seem well and good but I think you will have a problem getting the upper crank sensor out because it hits the alumium AC hose which can be moved. I recently decided that the AC compressor might have to be loosened in order to get enough room to replace upper crank sensor. Hope I am wrong!
Old 11-02-2007, 09:32 PM
I did not have clearance problems when removing either sensor. The only difficulty I encountered was reaching the sensors and bolts since I have large hands and arms.
