Old 10-10-2007, 06:50 PM
drew51074's Avatar
drew51074 drew51074 is offline
96 accord wont rev over 3k
i have a 96 accord 4 door auto and my engine wont rev pass 3k. i have a P1362- TDC sensor, P0453- EVAP sensor high pressure, and P0720- output speed sensor CKT malfunction codes popping up. im thinking its the TDC sensor, but can it be the speed sensor?? my D4 light is flashing too. any ideas??
Old 10-11-2007, 06:46 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 96 accord wont rev over 3k
Speed sensor could be causing your D4 light, but shouldn't be causing the short revs.
Several people have had the low revs problem...let us know what it was if you fix it, huh?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 10-11-2007, 04:03 PM
NesOne NesOne is offline
I had the short revs problem when I would get to 4K on my RPM's and it turned out that I was low on oil. I added 3 quarts (yup, that's how low it was), and low and behold, my car acted normal once again. So, try checking your oil...
Life's a Joke, and... Death is the Punchline
Old 10-11-2007, 04:07 PM
drew51074's Avatar
yeah, its got plenty of oil. i think i've narrowed it down to my dizzy. i removed the cap and it was filled with oil. the TDC sensor inside is probably fried. now i just gotta find another one. to the junkyard i go.
Old 10-12-2007, 11:21 AM
Alteris Alteris is offline
My 2000 accord did that i changed my distributor and distributor cap and it fixed it.
Old 10-14-2007, 11:17 AM
drew51074's Avatar
ok, its not the dizzy. crank sensor time. i've gone through all the manuals i've downloaded and i cant seem to find one that shows me where the crank sensor is located, or any sensor for that matter. i heard its somewhere behind the timing belt?? or in the oil pump somewhere?? if someone could link me to a diagram of all the engine sensors that would be great.
oh yeah, update. the D4 light flashing. there are two sensors located on the very tip of the passenger side of the tranny. i guess they monitor the actual tranny speed and tells the tranny computer when to shift. well anyway, i removed both and they looked like they had metal afros!!! alot of metal shavings magnetically attached to the tip of the sensor. im sure this screwed up any signal its supposed to be sending. i used some brake cleaner and cleaned them up and re-installed them. D4 light gone and so is the P0720 and the P0700 codes. pulled the EGR valve out too and cleaned it out also. it was pretty clogged up. that took care of the P1491 code. i had a P0453 code (evaporator system malfunction, faulty fuel pressure sensor) but it seems to have fixed itself.
just have this P1362 code hanging around. i'll keep you guys posted.
Old 10-14-2007, 02:36 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Cool Re: 96 accord wont rev over 3k
all those sensors are located in the distributor tdc and cps and icm and others too probably better to by a reman distributor instead of taking distributor apart takes too much time and if u dont do it right then you will have to buy a new one or reman good luck
Old 10-14-2007, 02:56 PM
drew51074's Avatar
someone told me there is one (crank sensor) located in the front of the engine somewhere around the timing belt. i actually found the sensors wire coming out of the bottom of the engine near the timing belt cover toward the firewall. is that the crank sensor harness?? if not, then what is it?? he also said some of them come with the crank sensor down there and some dont. i think this one does. maybe you are talkin about an engine that doesnt. this one is obviously wired for one so im assuming its there. i got a distributer from the junkyard and it didnt fix the problem. i even took a distributer from my friends 97 accord and it still throws the same code and revs to 3000 rpm. it works fine in his car, so its not the dizzy. i cant think of anything else at the moment that it can be but what the P1362 trouble code is telling me. TDC sensor or crank sensor.
Old 10-14-2007, 06:47 PM
wiseguy01's Avatar
heres a link for ur honda service manual download it and research it yourself
http://hondatech.info/downloads/Auto/Manuals/Accord/
Old 10-14-2007, 10:44 PM
drew51074's Avatar
i have them downloaded already. i know what it says but it doesnt show me what sensor is down by the crank pulley. something is down there. and i think thats where my problem is. does any of these manuals show you what this harness is thats going to the bottom side of the timing cover?? i've gone through 3 dizzy's and the problem is not there.
Old 10-14-2007, 11:15 PM
wiseguy01's Avatar
http://www.autozone.com/shopping/locsSelect non vtec
http://www.autozone.com/shopping/locsSelect.htm vtec
i am telling you there is no sensor down there check these links out or better yet go to autozone.com and look up the part and it will tell you where its located
Old 10-15-2007, 12:34 AM
drew51074's Avatar
there is no sensor there?? im looking right at the wires for it.. i'll take a pic of it 2mrw and show you. something is there. im sure these wires are attached to something. there are not there just for looks. lets say its not a crank sensor there. then what the hell is it? i find it a little difficult to believe a CRANK sensor would be in the dist. thats attached the CAM shaft.
Old 10-15-2007, 06:47 AM
Oddly enough Honda does put the CKP on the cam...which makes it a CAM position sensor in my book too but I'm no engineer
I can't find any reference to a position sensor located on the crank, and looking at a few pics of 2.2 cranks there's no sensor ring to exite a position sensor on them...
I'm not sure what the wires you see are for.
...empty gun rack.
Old 10-15-2007, 09:54 AM
Hey according to my info, PO1362 is Top Dead Center sensor, not Crank position sensor....
but they are both in the distributor...I suggest checking your wiring...1362 means no signal.
...empty gun rack.
Old 10-15-2007, 10:17 AM
Man I've been all over the place trying to find a solution to this for you as it keeps coming up from time to time....
All I've learned that I didn't know is that it's the ECU going into safe mode to protect against possible engine damage when it cuts at 3000 like that....and CKP/TDC sensor faults are the most common code associated with it. The most mentions of it were after engine swaps where they were either trying to use the wrong ECU for the motor or screwed up the wiring while putting things back together.
Ones that were unmodified got resolution after replacing the distributor or sensor(s), but many still had the problem after trying all that.
I still suspect it's a wiring issue. If you don't see anything visibly wrong with the wiring I'd get a pinout chart for that ECU and see if there is a signal present at the computer from the CKP and TDC/CYL sensors...
You might also try powering down the ECU to clear the fail safe mode (I don't know the Honda procedure, sorry) and see if the problem is gone until/unless the code sets again....
...empty gun rack.
