| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
96 sunfire misfire
my 96 sunfire 2.2l (check engine light blinks) misfires/idles rough/lacks power on acceleration.
i have checked wires/plugs/replaced both coils and ignition module/checked EGR valve its fine. what else could i check?
Re: 96 sunfire misfire
Pull the vaccuum line off of the fuel pressure regulator (it's on the end of the fuel rail) - if there is any fuel inside the vaccuum line, replace the regulator.
KCMike ASE Automobile Master Technician L1 Certified http://automotiveresource.org |
There are many things that cause a general lack of power though, that have nothing to do with a misfire. Low fuel pressure, or a restricted exhaust for example can cause a general lack of effeciency for all cylinders. You may want to get a service manual that explains the methods of testing for these basic things. It is a process of narrowing down the possibilities and then zooming in on the cause. Very hard for anyone to help without some specific information. But if you are a do it your selfer grab a manual, read some procedures, and post some results. I would be glad to respond if I can help. Good Luck!
KCMike ASE Automobile Master Technician L1 Advanced Engine Performance Certified http://www.automotiveresource.org |
thanks for the reply, i will get a manual. *update* replaced ignition module and both coils, didnt help. so rule that out.
Talk to you later.By the way, don't drive the car if you can avoid it. This kind of a condition can cause your catalityc converter to fail and cost you more money. It's a bummer I know, but it is a true story.
