Old 10-10-2007, 04:34 PM
ezwriter ezwriter is offline
78 400 timing specs?
1986 K10 with 78 400 motor.Anyone know the timing specs? Label shows 6deg but that's for the 86 engine. Timing mark was bouncing around so bought a new distributor,not put in yet.
2- Weird thing- hibeams won't go off so I put in a new headlight switch on the steering column, same thing! It clicks off ,dash lite goes off but hibeams stay on. eh??
Thanks in advance!
Old 10-12-2007, 02:59 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 78 400 timing specs?
Thanks in advance!
6 degrees should be just fine. The engines hardly changed at all in that short a time.
About the headlights, Generally you would create a thread for each seperate problem. Not a big deal, but it gives you better (or at least more) results.
If this is a new truck to you, check and make sure someone didn't splice the hi/lo '+' wires together or something like that. Also check the connectors on the low beams and make sure the plastic isn't melted, allowing the terminals to touch. If nobody has a definate solution by Monday, I'll check the wiring diagram while at work.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
