Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 10-10-2007, 11:02 AM
dmiller66 dmiller66 is offline
Steering squeel
Ok, so I went to that HMA website about my power steering squeel, but it was no help. The troubleshooting section only said to tighten the belt, well, the belt is tight. I had just finished my yearly oil change and my yearly transmission fluid change and I thought I might try to get the steering squeel stopped. I bled the air out according to the HMA website, change the fluid.....yet the squeel remains. The website did say something about a flow control valve.....does anyone know where that is??
Old 10-10-2007, 11:39 AM
Jalmir's Avatar
Jalmir Jalmir is offline
Re: Steering squeel
no, don't know about the flow control valve but usually an accessory squeel is due either because of the belt (not the case here) or the shaft bearing inside the accessory itself (the power stearing here).
I had a squeel I couldn't point out once on an old 89 Corolla, finally the alternator died and I found out it was one of the bearing inside the alternator that was causing the squeel, I had it rebuild and they changed the bearing, never squeeled after that.
Old 10-10-2007, 01:01 PM
Re: Steering squeel
Hey,
Thanks for the reply. This is what happens...when you turn the wheel, the pump locks up and the belt slips, it slips on the pulley that also turns the water pump. The pump is new plus it did this with the old pump, leading me to believe that the pump is not the problem. It started all of a sudden when I changed the belt. As soon as I changed the belt, the squeeling started. i didn't touch anything else. It was not making a sound before. Its to the point where it is embarrassing and Im considering replacing the car, even though everything still works fine. Thanks.
Old 10-11-2007, 04:32 PM
Jalmir's Avatar
Re: Steering squeel
ok then the belt itself is the problem, you better go get a new one directly at a Hyundai dealer!
Old 10-11-2007, 06:18 PM
Re: Steering squeel
I did!! The belt I have on it now is from the parts department at Hyundai! I thought I'd try that.......but it didnt work either.
