Old 10-10-2007, 10:45 AM
Jconnor Jconnor is offline
Right turn signal
I recently went camping and just found out that the right turn signal/brake lights do not work at the trailer connector. They do work on the truck. I always figured that if they worked at the truck, then the harness would be fine too, since it is factory installed. Everything else checks out fine. Is there a connection somewhere or a fuse that may be causing my problem. I'd hate to go digging through all that wiring.
Old 10-10-2007, 11:01 AM
rjeffery rjeffery is offline
Re: Right turn signal
DId you check the bulbs on the trailer?
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 10-10-2007, 11:11 AM
weo38 weo38 is offline
Check the fuse block under the hood. There is a fuse for Trailer lights, believe it or not. I know I spent a day under my snowmobile trailer before I read my manual to find out there is another fuse under the hood.
2009 Z-71 ECSB
2007 Yamaha Grizzly 700 FI
Old 10-11-2007, 09:49 AM
There was a blown fuse in the fuse panel in the dash. I didn't realize they would be on a seperate fuse than the truck. Thanks for the help.
Old 10-11-2007, 10:11 AM
Glad you found the problem. Are the right & left lights on different fuses?
Old 10-11-2007, 11:26 AM
Jeff, Yes they are. Very nice knowing that if one blows, you still have the rest.
