Old 11-28-2002, 05:14 PM
CustomWhips's Avatar
CustomWhips CustomWhips is offline
Send a message via AIM to CustomWhips
dying out when i stop why?
ok i drive a civic 99 dx sohc coupe
ever since the first time i installed my intake i noticed at stops it would die out. but i disconected the battery and the problem was corrected for a while. now this morning i get in my car and it wouldnt start. luckily i was on a hill and i poped the clutch in reverse and it started. well ever since this morning when i get to a stop at 0 mph it starts to die and sputter a bit, then it just cuts off. hardly even noticible. why the hell does it do this.?
Old 11-28-2002, 05:21 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
did you install the intake yourself? cuz it sounds like you messed something else up when you did that. i have never heard of that problem, take it to a shop i guess. is the check engine light coming on? because if it is, you can use the wires under the glove compartment to test what the problem is. it will blink the light so many times and that indicates what's wrong.
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 11-28-2002, 05:23 PM
i did
i installed it my self.
my friend had his installed. and his did it to. alot when he get on her hard.
i dotn think its the problem. everything is together just rite. dont know.
plus i installed the intake months ago. and just now the cars giving me troubles..
Old 11-28-2002, 09:49 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
vaccum *sp* leak maybe?
2002 Acura TL Type S
1991 Honda Crx Si
Old 11-29-2002, 01:22 AM
what is that?
Old 11-29-2002, 03:45 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i say change your fuel filter and use some fuel injection cleaner, both of these are inexpensive and will rule out a common problem. also maybe your car is running too lean, you can try and add more fuel and see if that helps
Old 11-29-2002, 11:46 AM
i think thats what its called, my friend has a 93?? vw fox and he put a filter on it and he forgot to connect a line and his car would start then die out
1991 Honda Crx Si
Old 12-02-2002, 02:26 AM
disonnected the battery and reconnected runnen great again
Old 12-02-2002, 01:02 PM
djnoodle djnoodle is offline
im no expert but it sounds like when your cutting off your battery its reseting your computer, once you ride it for awhile it might be reseting those setings. sorry, i wasnt to much help, just something to think about since resetting the comp makes it work fine
Old 12-02-2002, 01:18 PM
shepworldwide's Avatar
shepworldwide shepworldwide is offline
ur timing might be off...
:twoguns:"shepworldwide":twoguns:
96 integra for sale or trade
huge northest meet may 31st. come check it out.
