Old 10-09-2007, 05:56 PM
bobosimon55 bobosimon55 is offline
Knock Sensor
I did a gsr swap in the summer in a 95 dx. since i've been running the car the check engine light has been coming on giving me a knock sensor code. when I did the swap my nieghbor wired up the knock sensor and i'm sure he did a good job. At first i wasn't running on 91 and up gas and using 89. Started using 91, that did not fix the problem. I've been thinking it may be that I did not change the fuel pump or the knock sensr is just bad. oh yeah the reason i'm thinking the knock sensor may be bad is becuase it doesn't even retard the motor and v-tec still kicks in. maybe i'm wrong. anyone have any ideas or ran across this problem?
Old 10-09-2007, 06:13 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Knock Sensor
what ecu are you running?
Old 10-09-2007, 09:52 PM
Re: Knock Sensor
i'm running it with a p72
Old 10-09-2007, 09:54 PM
Kind of a Big Deal
Re: Knock Sensor
ok, if the knock sensor is bad, vtec shouldnt engage.. you sure the code it was throwin was for knock?
Old 10-09-2007, 09:56 PM
emt1134 emt1134 is offline
Re: Knock Sensor
I am a General Motora guy, don't know much about Hondas.. However, many GM ECUs have a separate knock sensor module that plugs into the ECU. If your ECU is missing this module, or has the wrong version, this will obviously give you nonstop KS codes. I would look into this.
Old 10-10-2007, 05:48 AM
Kind of a Big Deal
Re: Knock Sensor
good advice, but hondas knock board is soldered directly into the ecu internally. even if its bad, it doesnt explain why vtec is engaging while throwing a knock code, because it should be throwing the ecu into limp mode
Old 10-10-2007, 06:51 PM
Re: Knock Sensor
yeah my nieghbor has been saying the same thing. he said that if i'm getting a knock sensor code the car should run like ass. but it runs the same with the check engine light on or not. it's wierd. I think the motor may need a tune up. one more thing when we checked the motor out cylinder 3's piston rings were leaking by compression. I don't know but that may be what it is. I just haven't had the time to properly check it out.
Old 10-10-2007, 07:51 PM
Kind of a Big Deal
Re: Knock Sensor
i would find out whats causing the CEL... low compression wont throw a code
