probe is really starting to piss me off@!$%@
1995 ford probe se
o.k so this is what i know When I turn my car on I get alot of air coming out of the vents for about 2 seconds, then it shuts off and stops working, no air! all fuses are good I've tried replacing the relays nothing changed I have power to both the relay under the hood and the relay mounted next to the blower motor I have a little bit of power coming out of my speed control switch on my console only when in the 2 lower speed positions, when I put it in any of the 2 higher speed positions I dont get any power coming out of the switch. should I maybe try replacing the entire climate control module thingy?? or is there a resistor that could be shot? also my cruise control doesn't work, and my cooling/radiator fan doesn't work. i dont know if there is any connection??? one last thing is when I start my car I get a squeeling noise for a while, then it stops, maybe from a belt. could a bad belt be my problem? |
Re: probe is really starting to piss me off@!$%@
Hit the junkyard for a new switch assembly. Check your belts for proper tension / wear. They're cheap. So replace them even if they appear ok.
like he said, junkyard for module. they will be cheaper. and the belt. more than likely your serpintine belt. check the tension on it
