Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-09-2007, 12:24 PM
Asmasher Asmasher is offline
Angry 1990 suburban just wont frickin start!
I have a 90 gmc suburban with the 350 5.7L v8 and it wont start. It needed a fuel pump and that was replaced with a strainer and a sending unit. There is gas in the fuel line it is just not firing out of the injectors. They have no juice. Can't figure out why. It turns over fine and runs if you spray gas or starting fluid in the throttle body but wont stay running? Please help
Old 10-09-2007, 12:31 PM
Re: 1990 suburban just wont frickin start!
Oh and by the way its a 4x4 automatic
Old 10-09-2007, 01:35 PM
tkunkel tkunkel is offline
Can you hear the fuel pump prime when you turn the key to run? If not you have a wiring or fuse/relay problem. If you can hear it prime and it is a brand new pump you should try replacing the fuel filter.
Old 10-09-2007, 06:41 PM
2000CAYukon 2000CAYukon is offline
The injectors will not fire if the ignition module or pickup coil is bad. Most parts stores can test the ignition module.
//2000CAYukon
