Go Back   Automotive Forums Car Chat > Pontiac > G6
Old 10-09-2007, 12:17 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
G6 Horn
Where is the horn at on a 2006 Pontiac G6? The relay clicks, but the horn doesn't work.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 10-12-2007, 08:49 PM
emt1134 emt1134 is offline
Re: G6 Horn
the horn probably crapped out because of water intrusion. the horn is located by the left headlamp.. you will need to remove this. Then check for power at the connector on the green wire with the horn depressed.. if good, then check ground.. If both are good, then you need a new horn assembly.
