Old 10-09-2007, 12:16 PM
blu3kgt blu3kgt is offline
Gutting the pre cats
well i just wanted to make sure but if i gut my pre cats.. more that likely i will get a (CEL) ????if i do get a CEL will the o2 simulators be able to solve this problem
Old 10-09-2007, 12:32 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Gutting the pre cats
They should..
Old 10-09-2007, 07:02 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
You have a 97, yes it will throw a CEL. Get o2 sims from 3sx.
Old 10-09-2007, 09:01 PM
Hotshot8792 Hotshot8792 is offline
have fun gutting
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 10-10-2007, 07:44 AM
lol yea i heard it sucks but o well... well thanx i will go ahead and order the o2 simulators..... also another question do you think it will have at least a considerable hp gain or pull harder to redline?? basically i am asking is are the results from gutting the precats worth the trouble??
Old 10-10-2007, 06:00 PM
Stealthee's Avatar
Even only being SOHC I liked the difference. May not be much power, but every little bit helps.
Old 10-12-2007, 09:44 AM
mistermoonpie mistermoonpie is offline
SORRY, noob still learning the basics
What is a CEL?
What are o2 Simulators/what do they do?
I have a 97 SL and this sounds like a fairly simple (though time consuming) project...Will it mess with emissions and make my car illegal? Im not really lookin to do that.
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 10-12-2007, 09:59 AM
vectorspecialist vectorspecialist is offline
CEL: Check Engine Light
as for passing or failing emissions it just depends on the state you're in, each one is different...some dont even have inspection
as for o2 simulators...i dont know...can garuntee stealthee does
yup, here i am
Old 10-12-2007, 11:21 AM
the o2 simulators hook up to the o2 sensors... the o2 sensors get a certain resistance that they have to stay in, in order for your check engine light not to come on, so if you gut the pre cats, the o2 sensors will have a different reading and it will set the check engine light on. so you hook up the o2 simulators and they will simulate the resistance, making the ecu think that everything is ok, so your check engine light won't come on even though you have your precats gutted... so far to my knowledge i think that is what they do but stealthee would be a better source
Old 10-12-2007, 12:09 PM
Stealthee's Avatar
It wont mess with emissions.
As stated it makes the ECU believe the pre cat's properly functioning by sending the correct signals to the ECU.
Old 10-12-2007, 03:58 PM
new2mitsu new2mitsu is offline
from what i've seen the precats only function befor the car and exhaust is at running temp, after that all you need is the main cat
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 10-12-2007, 04:00 PM
Well then with o2 simulators telling my car that everything is ok with my engine, Will my CEL come on if there actually is a problem that I need to know about?
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
Old 10-12-2007, 04:27 PM
yea the cel will come on if anything else goes wrong....
Old 10-12-2007, 05:09 PM
Stealthee's Avatar
Yes the sims only affect the pre cat o2's
