Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-09-2007, 01:48 AM
vandok13's Avatar
vandok13 vandok13 is offline
Steering
1988 4runner, Auto, 35's, 22-RE
Just recently my steering started to clunk when i turn, mostly when i am going slowly though. It isn't too severe but i like to find out what this could be and is it a big concern?thanks in advance
Jvd
Old 10-10-2007, 03:37 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Steering
35's on IFS ? You're lucky it's just a clunk.
Could be a bad CV joint, or the steering relay rod could be worn out.
It could be the steering stops have the plastic cover(s) worn off, but that usually creates more of a screeching sound.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 10-10-2007, 04:43 PM
vandok13's Avatar
Re: Steering
Yeah its IFS, i have been planning on a front end swap but dont have the time to do it. Its a defenate clunk, it hasnt gotten worse since it started or more frequent, it only does it once in a while. I guess i will just wait for my front end to break seeing how its smaller and weaker than the solid front end, then i will swap it. Is the best way to do it is to just buy one of those coversion kits?......My Front end is pretty fucked up though, i buaght my truck and the running gear was in peices and i assembled it best i could. It works well and i havn't had any problems yet but i could use the more flex.It would be nice to stay on all 4 tires when i go wheeling. Here are some pictures
From the front
I circled in red where a peice was cut off, looks like there should be another crossmember here but the diff would be in the way
From the back
Any feedback would be great, i have never seen another setup quite like this and just wanted to know anything about it. Thanks in advance
JvD
