Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-08-2007, 09:57 PM
rpep1982 rpep1982 is offline
89 Cutlass to 96 gage swap
Does anyone know if you can install the 1989 cutlass instrument cluster w/ all the gages into a 1996 Cutlass with the standard speed-temp-fuel setup? The 89 cluster is physically the same as the 96 but I don't know if the computer will work with it.
Thanks
Old 10-10-2007, 08:22 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 89 Cutlass to 96 gage swap
welcome to AF.
I dont believe the 89 and 96 ICP's are physicaly the same cluster.
ALso the plug ins are not the same, so pin layout would be different.
ECU's are not the same either.
But nothings impossible, if you realy want it to work.
You'd need a wire diagram for both and match up the wires.
Not fun by any means
good luck
1999 Grand Am SS 3.4 OHV
