Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-08-2007, 09:26 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
Clogged/bad Catalytic converter
What are signs of a Catalytic Converter on the way out or plugged?
I get a lot of white smoke when i start up, and some funky smells, along with a really low idle, low enough it almost stalls, for the first 10 seconds, before idling normally.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 10-09-2007, 11:31 AM
Morley Morley is offline
Re: Clogged/bad Catalytic converter
White "smoke" is water in the exhaust...like maybe blown head gasket.
Old 10-09-2007, 03:52 PM
Thing is, wouldn't i have to be losing water for it to be a head gasket?
Old 10-10-2007, 01:23 AM
A head gasket will leak water, but it may be a minute amount at a time, especially if you only drive like 10 miles at a time.
Old 10-10-2007, 01:32 AM
goldz28's Avatar
goldz28 goldz28 is offline
You can see white smoke from mine when its real cold outside. If a cat is bad it can smell like rotten eggs. Take it to a exhaust shop and they should be able to take a heat gun to it and tell if its working or not.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 10-10-2007, 04:00 PM
Somebody was telling me that it might be my vacuum system causing it to run like this, i don't see how it would create the smoke, but i do reckon it would cause a crappy idle.
also, today i put it up on ramps to get the starter off, and about 10 seconds before i crawled under, the ramps just COLLAPSED, FLAT!
I will NEVER EVER get underneath a car that is on ramps again. If i had been under there 10 seconds earlier.........
Old 10-12-2007, 09:02 PM
sdsniper's Avatar
sdsniper sdsniper is offline
damn glad your alive. I always shake the car really hard before i get under...just to make sure. anyway i had white smoke coming out of my exhaust as well. Turned out i had a water leak on my fuel pump hose. i just fixed that now i don't really see any smoke coming out of it anymore. i wonder if its good just to replace a old cat with a new one.
Old 10-13-2007, 02:53 PM
Screw that, i'm not spending money on a cat, if i take it off, i'm putting a pipe in it's place. Round these parts, they don't sniff your exhaust.
