Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-08-2007, 09:04 PM
mvette76 mvette76 is offline
need some info
just bought a car that has a late 80's camaro 350 so i was told. the car is not runing it has a holly carb on it the first ? is does a fuel injected motor have fuel pump lobe it has a new fuel pump but not pumping gas second ?? how do i tell if this motor is a 350 what do i need to look for ??
Old 10-09-2007, 09:40 AM
MrPbody MrPbody is offline
AF -Advisor
Re: need some info
You identify the engine by the stamped code on the machined pad at the front, right side. You could also get the block casting number (7-8 digits) and the date code.
Earlier fuel-injected engines still had all the places machined for the fuel pump pushrod, and if a flat-tappet cam, the lobe is there. The pushrod isn't. If' it's a "roller" (hydraulic roller cam), it will have no lobe on the cam.
Later blocks didn't have the provision for the pump pushrod machined.
Jim
Old 10-09-2007, 05:50 PM
Re: need some info
thanks jim
