Old 10-08-2007, 07:53 PM
krumm411 krumm411 is offline
Code 33
A/c worked great 2 days ago now it wont even turn on. I get a code 33 open or shorted condition on a/c clutch circuit. What should I check? Wheres the relay for the a/c clutch. There are 5 by the battery but they arent labled. 93 grand caravan with the 3.3
Old 10-09-2007, 12:05 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Code 33
Welcome to the forum. If you're getting power at the clutch connector with the switch on, make sure the connector isn't corroded then change the clutch. If you're not seeing power check the circuit from the relay. Your best bet would be to buy a maintenance manual for $15-20 or get one from your local library.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
