Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-08-2007, 07:24 PM
nutrup nutrup is offline
Question Forgot O-rings on transmission filter
I just replaced the transmission fluid and filter on my 2000 Ford Ranger and realized I forgot to put the O-rings on the filter. Do I have to drop the pan and put the O-rings on or can I leave them off without any damage to the transmission?
Old 10-08-2007, 07:54 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Forgot O-rings on transmission filter
You need to replace the seal. If not the fluid can bypass the filter and cause drivability problems.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-10-2007, 08:53 PM
toddler62 toddler62 is offline
The pump might not be able to pick up the fluid from the bottom. Which I'm sure would hurt tranny. Drop the pan again and put O ring in. I would reuse the fluid again but be real careful to drain in clean pan and keep all dirt out of the fluid
