Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-08-2007, 04:12 PM
1.8LJosh 1.8LJosh is offline
93 Eclipse no spark
The car: 93 1.8L Mitsubishi Eclipse.
The Problem: I have no spark at the plugs the car just cranks.
I cracked the fuel rail to ensure gas was getting there and it is.
The plugs and plug wires are not even a year old and still look to be in good condition.
Spark plug gap is good.
I pulled the cap and rotor no moisture was found.
Checked all fuses and relays, all are in good order
I changed out the cap and rotor.
Double checked the firing order.
Lastly I pulled a working distributor and swapped it with mine thinking that pherhaps the coil was bad.
No luck at all with what i have done thus far.
Not one of the cylinders is recieving spark, right now I am stumped.
Thanks for the help.
Old 10-08-2007, 04:40 PM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
Re: 93 Eclipse no spark
My last 93 talon had a similar problem, but mine would eventually fire after between 5 and a million cranks. If this seems to be the case with yours, my solution was barometric pressure sensor, temp sensor, and TPS...I would advise trying the first to tho as I was young and foolish at the time and purchased all three instead of doing one by one...(TPS is about 250)
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 10-08-2007, 11:41 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Check the crank sensor.
95 Talon TSI AWD
97 Eclipse GST
