Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-08-2007, 12:25 PM
josh kroh josh kroh is offline
Exclamation 1986 carb tuning help???
well i reblaced my plugs on my 1986 buick regal and when i would get on the gas the car would shimmy weird at first when i hit the throttle so i double check the plug gaps wires rotor cap its all in check so i thought it could be getting to much fuel and started messin wiht the idle screw and am now at the point of no return and need some one elses help ne one know the factory setting or some advice it would be a hudge help thanks
Old 10-08-2007, 05:12 PM
maxwedge maxwedge is offline
A990 racer
Re: 1986 carb tuning help???
Welcome to AF, what engine, what idle screw mixture or speed?
Old 10-09-2007, 12:29 AM
thanks its a 5.0 v8 four barrel quad jet i started messin with the idle screw after replacing the plugs and getting a weird shimie when hitting the throttle so i figured it was getting to much fuel ended up dickin around to much and am now lost as far as the idle screw goes just wounderin the factory settings and or what i should do next
Old 10-09-2007, 05:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Turn the screw all the way in until it lightly seats (don't crank it down or you'll ruin it). Then turn it out 1.5 turns as a starting point.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
