Old 10-08-2007, 10:04 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Unhappy 5th Gear Slip?
I did some searching but didnt find anything...
Anyway, For a little while when i was in 5th gear, if i let off the gas it would slip out of the gear. Now its gotten worse and it will slip out of 5th even if im just driving normally. What could be cause ing this? syncros? its odd to me because its the fith gear and not the first or second.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 10-08-2007, 11:36 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: 5th Gear Slip?
look in the engine bay there is probably somthing in the way.. part the car and put it in 5th.. make sure there is nothing touching the cables in that position
Jason
Old 10-08-2007, 11:42 AM
liquidPunk's Avatar
Re: 5th Gear Slip?
where do i look? Ive never messed with the tranny at all, are the cables near the firewall?
-More to come-
Old 10-08-2007, 12:04 PM
jason_bet's Avatar
Re: 5th Gear Slip?
oh haha sorry umm your going to have too move your intake.. the cables go through the fire wall but the problem is going to be most likly where they connect to the tranny.. you will see the cables when you take out the air box/MAS sensor
Jason
Old 10-08-2007, 12:06 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: 5th Gear Slip?
Or it may be the nut that holds 5th gear in the transmission is backing off. That will cause it also, and if you wait too long you will break the case on the transmission. You need to take the endcase off the trans to get to the nut.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 10-08-2007, 01:02 PM
liquidPunk's Avatar
Re: 5th Gear Slip?
yikes, I have a feeling this is going to suck. Ill try to do some reseach while im trying not to work at work today
-More to come-
Old 10-14-2007, 10:57 AM
liquidPunk's Avatar
Re: 5th Gear Slip?
ok, I looked at the cables, they are pretty cool actually, i was shifting though the gears with them haha, They both looked good though, nothing blocking their paths or anything.
so how do i get to that 5th gear bolt skinny was talking about? I see some bolts on the tranny so im guessing i take a few of them off and then the cover comes off. Does this make fluid run everywhere? I looked online but couldnt find much on our transmissions, i was hoping for some pics so i could see where the loose bolt may be.
any help is appreciated guys
-More to come-
Old 10-14-2007, 11:42 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 5th Gear Slip?
search 3si in the FWD Drivetrain forum for posts by me. i've helped people with this very problem several times. as talskinny said, you'll have to remove the end case on the transmission. to do this jack the right front tire up, remove tire, remove plastic, remove end case (~10 10mm bolts). doing this will expose the 5th/reverse gear and intermediate gear. search through my posts in those threads and you'll find plenty of pictures to walk you through. basically you need to check the torque spec on the two end nuts, then stake them. if ur still having the pop-out problem, then you'll need to take apart the 5th/reverse gear sets and see if any parts are missing or broken.
http://www.3si.org/forum/showthread....light=5th+gear
http://www.3si.org/forum/search.php?searchid=2446169
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-14-2007, 11:49 AM
liquidPunk's Avatar
Re: 5th Gear Slip?
your an amazing man sire
-More to come-
Old 10-14-2007, 04:03 PM
liquidPunk's Avatar
Re: 5th Gear Slip?
So I just fixed my tranny! hell yes!...
ok, for future refference, the 5th gear kept poping out because of the loose nut as skinny had said. The symptoms began as the shifter in the cabin moving around a little when gas was applied or released and it was in 5th.
took the passenger tire off and the plastic, removed the 7 12mm bolts holding on the end of the transmission, and then i had to hit it with a hammer a little, there is a little nub that it sits on as well. a little fluid came out but not much and you must be carefull to not loose the spring and ring that can sometimes fall out. tighten the end nut (mine was way loose) on the larger gear (5th) you can check the nut on the other visable gear (intermediate gear).
put it all back together.. and done.
i just saved around $150 bucks, prob more.
-More to come-
Old 10-15-2007, 11:34 PM
Linebckr49's Avatar
Re: 5th Gear Slip?
did you torque the end nut to spec? i recall its 109 ft-lbs.
also, did you make sure to stake the nut so that it won't back off/loosen itself in the future?
93 3000GT base
Old 10-16-2007, 09:38 PM
liquidPunk's Avatar
Re: 5th Gear Slip?
I used that penny trick to tighten the nut and I did restake it. There were two notches on mine though i only saw one on your pics, so i staked them both (and that was kind of a pita.
-More to come-
