Old 10-08-2007, 10:52 AM
portboi28 portboi28 is offline
How to replace headlight assembly
Can anyone please tell me how to replace the headlight assembly on a 04 grand am?
Old 10-08-2007, 02:19 PM
Jmoney3318's Avatar
Jmoney3318 Jmoney3318 is offline
Send a message via AIM to Jmoney3318
Re: How to replace headlight assembly
im pretty sure there was a how to on this on here, but i cant find it but ill try to give u my step by step direction on removing them.
start off by popping the hood
(facing your headlights) you should see like a plastic cover sittin ontop of the headlights and covering the radiator and all that if you have a GT it will say Ram Air on it,
There should be 8 black plastic clips holding it in place, remove them using the back end of a hammer or a flat head screw driver.
Now remove the plastic cover thing and you should notice 2 metal pull up clips on both sides of the headlights starting on either side just pull them up.
when they are removed you can pull the headlight out.
my Cardomain
2002 3.4L V6 GA Coupe
-Xero is my hero--
mods:
Suspension: KYB GR2s, Intrax Lowering Springs, Upper Front Strut Bar
Engine: Custom 2.25" Exhaust,Doctorspeed Cold Air Box
Old 10-08-2007, 06:36 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Good Directions Jmoney!!
and Welcome to AF portboi28.
You also can check this thread out, has a few pics that might help.
99+ Headlamp Removal/Replacement
1999 Grand Am SS 3.4 OHV
