Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-08-2007, 09:04 AM
tripper225 tripper225 is offline
Motor swap by year and type
Hi All:
Working on two Nissan 240 SX cars
1. 1989 12 valve 2.4 liter engine
2. 1993 16 valve 2.4 liter engine.
My son wants to remove the 16 valve engine and install it in the 1989 auto.
Questions:
1. Do we need to swap the entire electrical cabling from the 1993 into the 1989?
2. Does anyone know of any technical issues that are difficult to overcome to accomplish the engine swap of the newer 16 valve engine into the older chassis.
Your help will be greatly appreciated.
Regards,
Jim
Old 10-08-2007, 10:13 AM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: Motor swap by year and type
easiest way to do the swap is to go ahead an swap out the 89-90 harness's (engine and tranny) for the new 91-94 harness's. you also have to use the newer ecu (as anyone could have guessed), swap is straight forward. plug in play if you have the harness's
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 10-08-2007, 10:36 AM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
new engine mounts
new tranny mounts
new clutch salve cylinder
new clutch master cylinder
new clutch
resurface flywheel
change the tack (u will be revving past 7000 rpm =)
let us know if u have any Q and good luck!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
