Old 10-08-2007, 08:55 AM
Arokh Arokh is offline
Blower motor or resistor?
1995 Grand Am 3.1, how would I tell the difference between a bad blower motor and/or resistor?
I had absolutely nothing this morning, it's like the blower motor wasn't even there. I know the switch is good so that's why I'm thinking it's the motor.
Does the resistor just control the speed? If that was bad, wouldn't it just get stuck on a certain speed?
Also, how do I go about replacing this? I just had the dash apart fixing something else and I don't recall seeing the motor. I think I gotta get at it from under the hood?
Thanks!
Old 10-08-2007, 03:14 PM
emt1134 emt1134 is offline
Re: Blower motor or resistor?
If you have HIGH speed but no others, then most-likely the resistor is blown... What you need to do is check your connectors for power and ground at the different speed settings.
Old 10-08-2007, 05:41 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF Arokh.
If you checked the fuse and have no speeds I'd think it was the blower motor.
As emt1134 stated check the plug for power on different settings.
You can also jump a wire to the blower to see if it is working.
And they are under the hood.
1999 Grand Am SS 3.4 OHV
