Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-08-2007, 07:25 AM
jaso1108 jaso1108 is offline
Cam Sensor Removal? Is there a trick?
Hi there,
It appears from the code I am pulling on our 1998 Montana 3.4 L that the Cam Position Sensor is bad. After following the wires, it looks as if it is located on the top of the engine, just to the right of the power steering reservoir.
First, does that sound like the right location? It's hard to see it very well, and as everyone knows, there are about ten sensors that look alike.
Second, is there some sort of easy way to get it out- from what I see it looks like I have to take off the power steering pump? Any guidance is much appreciated!
Thanks,
Jason
Old 10-08-2007, 04:08 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Cam Sensor Removal? Is there a trick?
IIRC I did not have to take off the pump, just loosen it and moved it out of the way. I did mine along with the EGR about 2 to 3 years ago and ended up doing it after dark because I did not allot enough time to do it,(took longer than I expected.)Once you access it, it's fairly easy to change out. A manual with pics is a good thing to use, and I used the new part to help differentiate it from the other sensors.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 10-10-2007, 10:39 AM
Thanks, I will try just moving the Power steering pump over without disconnecting the lines, and see where it goes!
-Jason
Old 10-10-2007, 01:08 PM
rkvons's Avatar
rkvons rkvons is offline
Originally Posted by jaso1108
Hi there,
Did you experience any undesireable symptoms from your vehicle prior to the code and, presumeably, the "Service Engine Soon" light? If so, what were they? Thanks.
Old 10-17-2007, 03:13 PM
No, nothing too extraordinary, just a recurring "Service Engine Soon" light- I thought intially it was some weird reaction to the gas, as it seemed to coincide with filling up the tank. But after it stayed on, I had Autozone pull the codes, and it came up with one for a cam sensor. Any other thoughts?
Old 10-18-2007, 12:22 AM
I, too, didn't have anything out of the ordinary happen when my went. My EGR also set a code at the same time, so I replaced both while I was in there. My EGR has set a code a few weeks earlier, and I took it off and attempted to clean some of the buildup in hopes that was the issue.
Old 11-06-2007, 07:47 PM
I finally got it changed out- I took out the power steering pump bolts, and was able to lift it up enough to get to the cam sensor with a couple of wobbly extensions and a lot of luck! Took about an hour though, it took a couple of shots (OK, maybe 5) to get the retainer bolt started.
Thanks for the advice!
