| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
1g BOV modding question
Hey guys, I have a question about 1g BOV modding/crushing. First off, as some of you know I am going for the stock appearing look on my Talon and that is going to include the BOV even though I hope to be running some high-ish boost (17-20 lbs low/daily, 22-25 (?) high/track) on some corn fuel. More background on my plans: supra SMIC and hard pipes (painted inconspiculously of course) before I turn the boost past stock, probably a CO2 IC sprayer before I try the high boost action, and definately want to get better at tuning and have a good tune on low boost before I attempt the high boost. Also, I am shooting for whatever power I can make out of a stock appearing car, so that goes for turbo too. I am thinking about an Evo III 16g, a TD05H 20g, or thought I talk a lot of shit about them, a TD05H 18g.
Well, I was planning on crushing my 1g BOV to help handle the pressure of the low boost, but I heard they usually start to leak at like 22 lbs right? I was going to do this mod so I can handle the higher boost. What do you guys think about this mod? Apparently it loses its responsiveness, is that going to end up in some compressor surge? It is reversible so I think I am going to do it anyway and just use it on race day, but if its not going to hurt anything I may just do it that way all the time. Kevin, your infinate wisdom would be much appreciated .EDIT: Fuck the 18g. E316g's will flow 38-39 lbs/min and cost $560 new while the 18g's are $800 and only flow 40lbs/min. One lb/min is definately not worth $240. |
Re: 1g BOV modding question
I think its a good idea if the bov is going to leak. Whats the worst that could happen, have to buy another one? And you can just leave that new port hooked up untill you turn up the boost controller.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Ah yes, the Gus mod. Gus Mahone was a local up here (CT). I talked with him extensively in the late 90s about this mod some time after he first introduced it. The short version is that I have been running a Gus modded BOV of one sort or another ever since.
![]() I currently run one on the EVO. I planned to use DSMlink nitrous controls to control it, but ended up running nitrous. So when I get to the track I just pull that Gus line and stick a 10mm bolt in it. At one point I installed a 3 way hand valve, but it was a little restrictive and wasn't really ideal (a little BOV noise even with the GUS line plumbed in). If you set it up on a TPS based control system, it will be just as responsive as a stock BOV. For reference, I ran over 30 psi on this BOV on the EVO. On the 2g I ran 35 before I eventually went to a Tial on the bigger setup. You can also build the whole thing using 1/16th NPT fittings if you're a faster and fitting junky like me. More expensive, but the end result is much nicer and more robust. I've posted in the past about how to properly crush a BOV using a vacuum hand pump, I'm sure that will turn up in a search if you haven't looked it up already. Well worth the effort. It's cheap, and it just plain works.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Mmmmm, this is good to hear. I was a tick worried that it was sort of a half assed way to do it, but not anymore. I just cant wait to get my baby linked with a decent IC/fuel system!
this answer my question too lol thanx
