Old 10-08-2007, 12:21 AM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
01 T&C squeaking sound when stops
It's coming from the rear. The back end lifts up somewhat when braking and until it comes to a complete stop and the rear lowers back down is when the squeak happens. So I checked some more, when I reverse and stop, and go forward and stop, it will squeak when it comes to a rest. Any ideals? Thanks
Old 10-09-2007, 12:37 AM
earlyrizr earlyrizr is offline
Re: 01 T&C squeaking sound when stops
can you make it squeak by bouncing the rear corner of the van?,I think yours also has the rear swaybar and maybe the bushings are going bad.
Old 10-09-2007, 02:51 AM
Yes it has the rear sway bar, and I did notice that the bushings are somewhat dry rot, however I did try to make it bounce but it did not make any squeak noise like I hear when it settles from a stop. Boy this thing is hard to bounce, I couldn't get it to move much. Could the leaf spring bushings cause this squeak? I did notice that where it mounts to the housing near the rear is very rusted, I don't know if the bushings are bad though. The rust is just on the leaf spring mount itself, nowhere else. Any other tests I can do? Thanks
Old 10-09-2007, 11:59 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
If you suspect a particular location of squeaking, if it's metal on metal, spray it with WD40 or the like. If it's a bushing spray it thoroughly with a silicone lubricant. It's a process of elimination.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
