Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-07-2007, 02:10 PM
coltonk coltonk is offline
85 4runner - Broken Valve Spring
I have a broken valve spring, does anyone know if it is possible to change it without pulling the head??
Old 10-07-2007, 06:57 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 85 4runner - Broken Valve Spring
Yes - There are a number of methods that you can use. Put the piston at top dead center on the compression stroke and remove the spark plug. Push small diameter nylon rope into the spark plug hole untill no more will go in, leaving some of the rope outside so that you can pull it out when you're done. The valve should be held in place by the rope if you have pushed it in tightly enough.
It is best if you remove the rope and replace the spark plug afterward....
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-07-2007, 10:35 PM
Thanks for the advice I will try that. One other problem though. How do you get the valve spring off with the rocker arms there. I really dont want to tear everything down to the timing chain to remove the rocker arm assembly.
Old 10-07-2007, 11:49 PM
Brian R.'s Avatar
Resident Chemist
I may be wrong, but I think that all you have to remove is the head cover to remove the rocker arm assembly.
Old 10-08-2007, 07:47 PM
Thats true but to remove the rocker arm assembly I think I have to remove the timing chain sprocket. I may get luck enough to just loosen the rocker arm assembly to slide the rocker arm for this valve to the side. Hopefully I can give it a try this weekend.
Old 10-08-2007, 10:18 PM
Brian R.'s Avatar
Resident Chemist
Good luck
Old 10-17-2007, 07:41 PM
ok ... so im an idiot.
I could have sworn that the rocker arm assembly was attached to the timing chain gear. boy was i wrong.... thanks for all the help everyone.
One more thing though... Im now looking at rebuilding the engine, I would like to get a bunch more power without sigificantly sacrificing gas mileage or needing to use a higher octane fuel.
Old 10-17-2007, 09:04 PM
Brian R.'s Avatar
Resident Chemist
http://www.toysport.com/Technical%20...tech_notes.htm
http://www.4crawler.com/4x4/CheapTri...ds/index.shtml
http://www.4x4wire.com/toyota/tech/camshaft/
http://www.4x4wire.com/toyota/tech/cam_degreeing/
